Activity Forums Apple Final Cut Pro Legacy custom keyboard – selecting clips in timeline
  • custom keyboard – selecting clips in timeline
    Posted by Rob Grauert on June 23, 2009 at 6:00 pm
    Today I decided it’s time to customize my keyboard layout. I assigned something for all the Function keys along the top and I changed the shortcut to “add edit” (which cuts all tracks) to “1”. One problem though:
    I don’t have a command for selecting which portion of the clip I want to delete from the timeline after I cut the clip, ya know what i mean? So what is that action referred to as? If I don’t know what that’s called, then I can’t change it to my desired shortcut.
    If I can do that with the keyboard, then the only thing I need my mouse for is going on Myspace.
    Thanks.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    Kevin Monahan replied 17 years, 3 months ago 3 Members · 4 Replies
  • Kevin Monahan
    June 23, 2009 at 7:20 pm
    What you want to do actually takes 3 moves:
    1. Mark Clip = X
    2. Select between In and Out = OPT + A
    3. Ripple Delete = DELETE or Shift + Delete
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Rob Grauert
    June 23, 2009 at 7:25 pm
    yes. that is exactly what I was looking for…just didn’t know what it was called.
    Thank you.
  • Tom Wolsky
    June 23, 2009 at 8:48 pm
    Don’t usually need the second step unless you already have something selected.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Kevin Monahan
    June 23, 2009 at 9:53 pm
    Right Tom. With Auto-Select you usually don’t need to do that step. Often though, I do have something selected. I’d call Step 2 a “failsafe”.
    Also, you do have to have Auto Select selected properly so you can get Mark Clip to work properly.
    Kevin Monahan
