Activity Forums Apple Final Cut Pro Custom Clip Naming gets order wrong
  • Custom Clip Naming gets order wrong
    Posted by Michael Garber on April 20, 2012 at 4:29 am
    Hi all,
    Someone posted this a while back and there was no answer to it. So, I am assuming this should be filed under bugs to be fixed.
    That said, if anyone has any info on a workaround for this, please let me know.
    I have a bunch of clips and want to give them a custom name based on reel name and clip number in order of date created. Pretty normal stuff. But FCP renames them out of order.
    I haven’t yet been able to figure out what metadata FCP is using in the way it orders the numbers of the clips. Maybe that’s the culprit.
    In any case, a trouble ticket has been sent. Look forward to someone’s response. Thanks!
    Michael Garber
    5th Wall – a post production company
    Michael Garber replied 14 years, 5 months ago 5 Members · 5 Replies
  • Frank Valtellina
    April 20, 2012 at 5:11 am
    I have the same problem. Sometimes I use a simple “Rename” program to change the files name in Scratch “Original Media” folder. If someone knows another way…
  • Jeremy Garchow
    April 20, 2012 at 1:53 pm
    I’d like to try and help, but can you give me your exact steps?
    Jeremy
  • T. Payton
    April 20, 2012 at 2:30 pm
    This appears to be a known bug. I have reported it to Apple, but it would be great to share your feedback to because “the squeaky wheel gets the grease.”
    https://www.apple.com/feedback/finalcutpro.html
    BTW. It is no joke when Apple says they read all the comments to that form. They really do read all the feedback.
    T. Payton
    OneCreative, Albuquerque
  • Tony Sarafoski
    April 20, 2012 at 3:53 pm
    I had this same problem when I updated .3 to .4, however I decided to re-format my OS (don’t ask) and downloaded a fresh 10.0.4 directly from the app store.
    Problem is now gone..!
    Try this for curiosity, create a new user account, open applications, click on FCPX & allow it to install, then import some material and try batch renaming.
    Let’s us know how you go?
  • Michael Garber
    April 22, 2012 at 7:35 pm
    [Tony Sarafoski] “Try this for curiosity, create a new user account, open applications, click on FCPX & allow it to install, then import some material and try batch renaming.”
    Thanks for the tip. Unfortunately, didn’t work for me. Will try re-downloading the app and let you know.
    Michael Garber
