Activity Forums Maxon Cinema 4D curved lines on the surface of a model
  • curved lines on the surface of a model
    Posted by Masha Troitskaya on April 27, 2017 at 1:16 am
    Hello. I have a pyramid model for animation and I need to put a different texture on its 4 sides.
    I can drow straight lines on the surface of the model with Polygon Pen but I’m stuck with these curved corners. Is it possible to drow them? What instrument should I use?
    Corrado Carlevaro replied 9 years, 4 months ago 2 Members · 1 Reply
  • Corrado Carlevaro
    April 27, 2017 at 11:35 am
    I think you should leave the geometry as it is, without new cuts as they could look bad when rendering, and apply the texture with an Alpha channel shaped as a rounded triangle.
    Corrado
