Activity › Forums › Adobe After Effects › curve frame
  • curve frame
    Posted by Rdub on June 25, 2009 at 8:07 pm
    I have a frame for hanging pictures in a scene. It is just a flat frame. I would like to give a bit of a curve to it. Any suggestions?
    Kevin Camp replied 17 years, 3 months ago 2 Members · 1 Reply
  • Kevin Camp
    June 25, 2009 at 8:19 pm
    you could also get creative with the c cylinder effect… if you first place your footage in a comp that s much wider than the footage (maybe 5-10 times wider), bring that comp into a new standard sized comp, then apply cc cylinder to the nested wide comp the footage will have a slight curve to it and will react naturally with 3d camera movements…
    it’s not ideal, but it may work…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
