Activity › Forums › Apple Motion › Curl an image in 3D space from the XY plane – Motion 4
  • Curl an image in 3D space from the XY plane – Motion 4
    Posted by Chris Finley on October 3, 2009 at 11:37 am
    I’m trying to find a way to take an image/video, and curl it in 3d space – essentially wrapping the image to the inside of a hollow cylinder. I’ve tried playing around with all the standard filters and they all seem to just alter the image when viewed from straight on but are always flat viewed from the side….
    I’ve attached a video of my project so far, which is 24 hexagonal rings of multiple dropzones that the camera flies through – I’m tring to bulge out the center of each dropzone so the ring shape will be a smooth circle instead of a hexagon
    example: https://finleycs.com/other/dropzone-wormhole.html
    Zak Peric replied 16 years, 12 months ago 3 Members · 5 Replies
