Activity Forums Adobe Premiere Pro Cue points imported from Audition as markers – can they be used to separate clips or export in Premiere Pro?
  • Cue points imported from Audition as markers – can they be used to separate clips or export in Premiere Pro?
    Posted by Joe Holdsworth on February 25, 2015 at 3:15 pm
    Hi all,
    I have imported separate video and audio tracks into a Premiere sequence, and have retained the Cue markers that I attached to the audio’s WAV file.
    These markers separate sections in the interview audio, and I would like to simply export each of these designated sections from Premiere Pro as a separate video clip. Is this possible?
    Basically, my ideal situation is:
    Audio WAV has ~30 markers named with particular information like: ‘This is important info’
    When I import into PP, these markers are visible on the audio track
    – Now, I would like to be able to simply batch export these discrete sections to filenames like ‘This is important info.avi’.
    Does anyone know if this can be done? No video markers or subclips exist at this point.
    Joe
    John Mcclary replied 2 years, 6 months ago 2 Members · 1 Reply
