Activity › Forums › Adobe After Effects › cube transition
  • Graham Quince
    September 23, 2022 at 2:13 pm
    Yes – you’ll need to use the 3D layer option and I would suggest parenting to a null object, but it should be simple.
    • Set up your layers
    • Turn on 3D
    • Create a Null Object layer
    • Make this 3D
    • Move it back in space by half the width of your layers
    • Parent the second layer to the null object
    • Rotate the null 90 degrees
    • Parent the first layer to the null.
    • Keyframe the rotation
