Activity Forums Adobe After Effects CTI problem
  • CTI problem
    Posted by John Gallagher on December 4, 2011 at 10:58 pm
    Hi folks, hope you’s all well.
    I’m currently educating myself with After Effects CS 5.5 and I have an irksome problem. If I create a new composition from the project panel or from the menu bar and then add files (video, stills, audio etc)to the timeline, I can’t do anything within the timeline, I can’t move the CTI, can’t trim the clips, nothing! However, If I drag a file to the new composition icon in the projects panel and create a new composition that way, everything works fine. Anyone know why?
    Much appreciated.
    John
    Angie Taylor replied 14 years, 9 months ago 2 Members · 3 Replies
  • Angie Taylor
    December 5, 2011 at 9:56 am
    Hi John,
    Good morning! I think the first thing to check would be the Composition Duration. With the Comp active, got to Composition > Composition Settings and make sure it’s the length you need. I suspect that you may have inadvertently created a comp with a Duration of 00:00:00:01. This could explain why you can’t do any time based operations.
    Hope this helps!
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • John Gallagher
    December 5, 2011 at 12:13 pm
    Hi Angie, you were spot on, I’ve sorted it now and it’s working fine.
    Thanks so much.
    Cheers,
    John
  • Angie Taylor
    December 5, 2011 at 4:05 pm
    Very Happy to help! 🙂 It’s happened to all of us at one point or another! 🙂
    cheers,
    Angie
