Activity Forums Adobe After Effects CTI moving in time weirdly
  • CTI moving in time weirdly
    Posted by Sebastian Moreno on October 24, 2017 at 11:42 am
    Hi all
    I am doing a quick script to move the current time indicator to a new time given by a edittext field.
    so far works to go backwards but behaves differently when I try to go forward in time:
    btn01.onClick = function () {
    var textInput = Input.text;
    var active = app.project.activeItem;
    active.time -= textInput; //works fine
    btn02.onClick = function () {
    active.time += textInput;
    // works in a digit + digit way
    // so if I entered 1 and the current time is 1 it would be: 1+1=11
    any ideas how this can be solved?
    Thanks in advance
    Walter Soyka replied 8 years, 10 months ago 2 Members · 1 Reply
  • Walter Soyka
    October 24, 2017 at 1:34 pm
    activeTime is being recast as a string because textInput is a string. Therefore, the number 1 is being recast as a string ‘1’ and then concatenated with another string ‘1’, yielding ’11’. You want to make sure that your textInput is understood explicitly as a number.
    Try:
    activeTime += parseFloat(textInput);
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
