Activity › Forums › Adobe After Effects Expressions › CSV driven Graph as MOGRT and the 32768-Limit – any way to get around this?
  • CSV driven Graph as MOGRT and the 32768-Limit – any way to get around this?
    Posted by Christian Waldhofer on June 29, 2021 at 7:17 am
    Hey!
    I have the following issue, and maybe some of you encountered the same problem 🙂
    I built a CSV-driven graph in AE using the footage(“”).dataValue([x,y]) method, which is (as far as I know it) the only way to get numbers out of a CSV that exceed 32768.
    But now, here is my problem:
    I actually want to convert this into a MOGRT so I can swap the data out, which (at least I think) means, that I need to put the CSV into the timeline and reference it directly, so that I can pull the data into the Essential Graphics panel. And I’m stuck again with my 32768-Limit.
    I already tried (and believe me, it was tedious) to add a /10 to every entry but as soon as you replace the CSV with a new one, I see once again just 32768.
    Am I missing something here? Does anyone have an idea on how to approach this?
    I know that I could just manipulate the CSV, but I hope that I can find a solution without doing that.
    Thanks for your help!!
    Christian Waldhofer replied 5 years, 2 months ago 2 Members · 2 Replies
