Activity › Forums › Web Design (WordPress, Joomla, etc.) › CSS Background Images as Borders
  • CSS Background Images as Borders
    Posted by Dave Potts on December 7, 2007 at 9:15 pm
    I was checking out msnbc.com this morning and I really like the micro beveled column borders that they have. It looks like they’ve used a tall 1 or 2 px wide image (I’ve posted it at https://video.uncc.edu/graphics/utility/v2/grid-border-fade.gif) as a non repeating background image in their divs, which seems simple enough. What I can’t figure out is that the image seems to stretch or shrink to fit the height of the column instead of repeating itself. Am I looking at this right, or is there something I’m missing? Any help on how to pull this off would be appreciated.
    Dave Potts
    Broadcast Communications
    University of North Carolina @ Charlotte
    Abraham Chaffin replied 18 years, 10 months ago 2 Members · 3 Replies
  • Abraham Chaffin
    December 7, 2007 at 9:25 pm
    I would assume they are vertical aligning the background image to the bottom so that the fade always happens from lightest at the bottom to solid at the top – then you can have a background color with the same color as the top of the graphic to fill in where the background no longer repeats.
    Abraham
  • Dave Potts
    December 7, 2007 at 10:29 pm
    I hadn’t thought of aligning the image to the bottom, that helps point me in the right direction I think. I’m not sure I understand how you would have that background color not stretch all the way across the div though. I’ve heard CSS3 will support multiple BG images…
    Dave Potts
  • Abraham Chaffin
    December 7, 2007 at 10:35 pm
    You can set it to not repeat and then align it to the bottom right of the div.
    <style type="text/css">
    Abraham
