Activity › Forums › Adobe Premiere Pro › CS6 Premiere – Waveform monitors
  • CS6 Premiere – Waveform monitors
    Posted by Jim on June 1, 2012 at 4:22 pm
    this could just be a new to CS6 oversight, but — is there a way to use the 3 way CC in CS6 and have the waveform monitors on screen an updating as changes are being made? I am able to get the color wheels & waveforms on screen at the same time, but there doesn’t seem to be a connection between changes in the wheels and the waveform monitors. Has anyone covered this in a tutorial?
    As always, thanks for you insights.
    Michael Murphy replied 14 years, 3 months ago 3 Members · 3 Replies
  • Ann Bens
    June 1, 2012 at 5:04 pm
    Try the vectorscope instead of the waveform.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Jim
    June 1, 2012 at 5:26 pm
    I found that if I change the Reference Sequence monitor to Waveform and gang to Program monitor, I’m starting to get some updates when 3 way CC is changed. I can certainly use Colorista or Looks to do CC, but for minor tweaks I’d always used a 3 way (FCP). I’d love to get a more in depth explanation of the the workings of the scopes and CC.
    Any insights would be appreciated.
    Cheers,
  • Michael Murphy
    June 4, 2012 at 3:49 am
    This has a decent explanation of using the Vectorscope to color correct in Premiere.
    It is an older version, but should transfer easily. Quite useful:
    https://provideocoalition.com/index.php/editingpost/story/streamlining_color_correction_in_premiere_pro/P2/
    Did you open the Color Correction Workspace to get the Reference Monitor? I think that automatically gangs the window to the Program window. Then you can just use the drop down for the scope.
    Good luck!
    Michael
