Activity Forums Adobe Premiere Pro CS6 playback is unusable. Something must be wrong with MY configuration.
  • CS6 playback is unusable. Something must be wrong with MY configuration.
    Posted by Cassidy Clawson on May 17, 2012 at 1:33 am
    Hello all,
    Just imported a CS5.5 premiere project into a fresh clean install of CS6 and I am trying to get to work.
    I have a bunch of 1080p prores footage. It plays choppy at full res, single stream. Maybe 3 or 4 FPS. When I render the footage, it still plays back choppy. It almost barely plays at full speed at 1/4 resolution.
    I am working from a FW800 G-Drive with the media cache and library set to that drive. CS5.5 gave me no trouble with this configuration.
    I have the fastest 2011 MBP with 8gb ram.
    What the heck is going on? This must be a setting or something…
    Thanks all
    Cassidy
    Anthony Uribe replied 13 years, 5 months ago 3 Members · 3 Replies
  • Cassidy Clawson
    May 17, 2012 at 8:27 pm
    Fixed the problem!
    I had hardware assisted mercury playback enabled (CUDA) when I do not have a CUDA card. This is the default setting I guess. I changed it to software only in Project > Project Settings > General
    WOO HOO! CS6 is screaming now.
    Cassidy
  • Stephane Dumont
    June 13, 2012 at 1:59 pm
    Cassidy,
    Thanks for clearing up this issue. I just upgraded to CS6 and was going crazy trying to figure out what the problem was.
    The program is working great now and can continue with work. Hopefully other people find this post as I have been on many others with related issues without a proper solution.
  • Anthony Uribe
    April 13, 2013 at 10:24 pm
    This just cleared up my headache too! Thank you!
