Activity Forums Adobe After Effects CS6 not properly converting Illustrator file?
  • CS6 not properly converting Illustrator file?
    Posted by Mike Imam on January 23, 2014 at 3:33 pm
    Hi all,
    I briefly posted this question in a separate thread along with a different question, but it’s big enough of a head scratcher to break it out:
    I’ve imported an Illustrator file into AE CS6, with the intent of extruding it in 3D. I drop the following image onto my timeline:
    Then I right click on the clip and select “convert shapes from vector layer”. The problem is I end up with this:
    I can’t figure out what I’m doing wrong. It looks like the outlines are there, but they’re not appearing for some reason:
    Anyone have any ideas as to how to get AE to properly convert this?
    Roland R. kahlenberg replied 12 years, 8 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    January 23, 2014 at 4:43 pm
    There are highly complex paths at play here – it’s difficult to see what’s the issue. Having said that, if you’ve done your export correctly and the import into AE went well then the issue has to do with the Fill Rule for Shape Layers – more info here.
    Alternatively, why not copy-paste your paths from AI directly into a Shape Layer in AE?
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
