Activity › Forums › Adobe After Effects › CS6: Manually place track points
Posted by George Loch on October 18, 2012 at 8:27 pmIs there no way to place 3D tracking points in the new CS6 tracker?
-gl
twitter: @georgeloch
web: https://georgeloch.comRoland R. kahlenberg replied 13 years, 11 months ago 2 Members · 1 Reply -
1 Reply
October 18, 2012 at 11:26 pm[George Loch] “Is there no way to place 3D tracking points in the new CS6 tracker?
“Nope! However, if your tracked points are on the same plane as where youwould like to place an object, then you should be able to offset the target area, which you define by MANUALLY selecting three or more tracked points which creates a Target Area (that strange dartboard thingy). You then move your cursor to the center of the Target Area until a four-pointed icon appears below the cursor. In this selection mode, you will be able to offset the position of the Target Area along the plane where it currently resides.
You could of course do this offsetting later, after creating your Solid/Null/Text but this method is more precise and doesn’t require that the view axis modes view is set correctly to accomodate the desired offset.
A good tip is to increase the contrast of your tracking plate in a precomp. This routine usually provides the tracking algorithm with more areas to track; resulting in more tracked points.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
