Activity Forums Adobe After Effects CS6 Full resolution export issues
  • CS6 Full resolution export issues
    Posted by Eva Kay on April 28, 2020 at 4:46 pm
    Hi there,
    I’m having problems exporting my Motion graphics sequence in Full Resolution.
    I never have issues with it but for some reason in this sequence when I export if for 2048/1080 when trying to play it back it only shows part of the frame not the actual full frame . I checked that the player fit to screen but that doesn’t help.
    So basically let;s say I have a chair and a desk in the full frame what I’m seeing after exporting if only the leg of the desk ‘zoomed in’ in a way and that’s when the player is set to fit to screen.
    It doesn’t happen with MOV files though only with motion graphics elements
    Any tips ? I have to go into a grading session tomorrow and I can’t export!
    Eva Kay replied 6 years, 4 months ago 2 Members · 13 Replies
  • 13 Replies
  • Walter Soyka
    April 28, 2020 at 5:29 pm
    Can you share some screenshots of your UI? Something that shows us what you see in Ae, versus what you see in the rendered movie?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Eva Kay
    April 28, 2020 at 5:39 pm
    Hi Walter,
    Thanks for replying …so what I found out in the meantime is that when I turned off layers that were Jpegs and only kept the MOV layers the problem is gone so now I have to figure out how to force those jpeg files which have a lot of effects on them to maintain the resolution
    Any clue ?
    Eve
  • Eva Kay
    April 28, 2020 at 5:41 pm
    Hi ,
    So what I found out is that layers that are jpeg have caused it . When I turned it of the problem doesn’t exist. How do I force the jpeg layers that have a lot of effects on them to maintain resolution?
  • Walter Soyka
    April 28, 2020 at 6:08 pm
    It’s hard to prescribe a solution without being able to see anything about your project to diagnose the problem.
    Is there anything you can share so that we can see what you are seeing?
    Walter Soyka
  • Eva Kay
    April 28, 2020 at 6:12 pm
    Sorry I’m trying to upload not sure if you will see it
  • Eva Kay
    April 28, 2020 at 6:15 pm
    that’s what it is supposed to look like . I also tried exporting a jpeg file or a DPX nothing works …this usually doesn’t happen and I work on my machine a lot but I admit usually I work with MOV files so it must be some sort of setting I am not aware of
  • Walter Soyka
    Thanks, but I was hoping to see some of your Ae UI — the timeline, the layers, etc.
    Is it possible that your view in Ae is not set to “Active camera?” This could cause a difference between what you see in the viewer panel and what you see in renders.
    Walter Soyka
  • Eva Kay
    April 28, 2020 at 6:23 pm
  • Walter Soyka
    April 28, 2020 at 6:39 pm
    What do you see if you set the viewer to Full resolution?
    What effects are you applying to the JPEGs?
    What are the dimensions of the JPEGs?
    Walter Soyka
  • Eva Kay
    April 28, 2020 at 6:46 pm
    Walter,
    full resolution doesn’t change the frame it’s just higher in resolution on the viewer
    Here’s screen shots of the doc size and the effects for this specific sequence
