Activity › Forums › Adobe After Effects › CS6 Full resolution export issues
Walter Soyka
April 28, 2020 at 6:51 pmIf it looks different in your viewer at full res than it does in your output, can you post your render queue settings?
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Eva Kay
April 28, 2020 at 6:57 pm -
Eva Kay
April 28, 2020 at 7:16 pmSo looks like I found what the problem is (at least I hope so). I have tried a different sequence with the same setting and this problem doesn’t occur there so I think it is the BG document I’m using that for some reason is causing it.
In the new sequence I am using a different BG Jpeg Document with the same effects but there is no issue there.
So the solution- replace the BG Jpeg layer …Thanks for you time Walter and stay safe!
