Activity Forums Adobe Encore DVD CS6 EN Resolution Question
  • CS6 EN Resolution Question
    Posted by Frank Giardina on October 28, 2012 at 7:52 pm
    Hi All…
    Well, I just authored my “FIRST” DVD using Encore. The project was edited it in Adobe Premiere CS6. I was working with 1920 x 1080 DSLR footage. I did a Dynamic Link timeline workflow into Encore. Everything I saw indicated the DVD would be (720×480). I used all the default settings hoping the quality would be acceptable, and it is not.
    I could use some encouraging advice everyone. Can I do ANYTHING with the bit-rate or some other setting to help?
    Best Sunday Afternoon Regards!!
    Frank Giardina
    17 Video Production
    Frank Giardina replied 13 years, 11 months ago 2 Members · 2 Replies
  • Daniel Ludwig
    October 30, 2012 at 5:54 am
    frank,
    SD-NTSC DVD is 720×480, and if you have been editing 1080-material it´s like crap in your eye – you get hurt when you see SD vs HD. 😀
    you´ll get the best SD-resolution if you are going to scale down first prior SD-MPEG2-encoding using a high quality downscale-tool. after effects could do a good job on it.
    don´t use HD-content within encore to create a SD-DVD.
    cheers
    danny
  • Frank Giardina
    October 30, 2012 at 12:42 pm
    Thanks Danny…
    Scaling down will be a first for me… I’ll check it out.
    Best Morning Regards!
    Frank Giardina
    17 Video Production
