Activity › Forums › Adobe Premiere Pro › CS6 (6.0.2) crashes on quit every time, any ideas?
Grégoire Giral replied 13 years, 3 months ago 8 Members · 14 Replies
Michael Cox
February 16, 2013 at 1:43 amI have noticed one thing which may be a cause (but not the only cause) of this hang: quitting Adobe Premiere while AME is running, AME might be accessing Premiere (i.e. to transcode audio); this happened just now, and once AME had finished importing the soundtracks Premiere closed.
Göran Thorén
February 16, 2013 at 8:08 amThank’s for that heads up regarding AME!
I rarely use it so that could not be an issue in my case though.
AME is a whole story by itself that Adobe needs to take a serious look at.
In my case I can’t batch export AME anymore for instance.
And then there is the pixel aspect issue when trying to get an SD FHA from an HD source…. -
Craig Ricker
May 13, 2013 at 12:52 amIm getting the same issue. Premiere keeps crashing on exit from my project. Its only on this specific project. I have dynamic links going to 1 AE project.
This is the crash log
Process: Adobe Premiere Pro CS6 [1500]
Path: /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/Adobe Premiere Pro CS6
Identifier: com.adobe.AdobePremierePro
Version: 6.0.2 (6.0.2)
Code Type: X86-64 (Native)
Parent Process: launchd [226]
User ID: 501Date/Time: 2013-05-13 10:49:35.685 +1000
OS Version: Mac OS X 10.8.3 (12D78)
Report Version: 10Interval Since Last Report: 5606 sec
Crashes Since Last Report: 1
Per-App Interval Since Last Report: 4977 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 117B489B-FDB6-253E-2253-C992C67974DACrashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLTThread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.adobe.premiere.frontend 0x000000010c72b74b FE::Application::AttemptPanicProjectSave() + 21
1 com.adobe.premiere.frontend 0x000000010c78327c UnixInterruptSignal(int) + 44
2 libsystem_c.dylib 0x00007fff8bdde94a _sigtramp + 26
3 libsystem_kernel.dylib 0x00007fff927c30fa __psynch_cvwait + 10
4 libsystem_c.dylib 0x00007fff8bdf4fe9 _pthread_cond_wait + 869
5 com.adobe.dvacore.framework 0x00000001001ebee4 void boost::condition_variable_any::wait(boost::unique_lock&) + 140
6 com.adobe.dvacore.framework 0x00000001001e97a8 dvacore::threads::Gate::PassThrough(int) const + 496
7 com.adobe.dvacore.framework 0x00000001001e5a4c dvacore::threads::(anonymous namespace)::SubExecutor::Flush() + 232
8 com.adobe.Backend.framework 0x000000010165cf0a BE::ShutdownMediaRelinking() + 58
9 com.adobe.Mezzanine.framework 0x00000001053e2673 MZ::(anonymous namespace)::MLInitializer::~MLInitializer() + 15
10 com.adobe.Mezzanine.framework 0x00000001053e29ca MZ::(anonymous namespace)::FullInitializer::~FullInitializer() + 182
11 com.adobe.Mezzanine.framework 0x00000001053ebd15 MZ::Initializer::PrivateImpl::~PrivateImpl() + 29
12 com.adobe.Mezzanine.framework 0x00000001053e1b98 MZ::Initializer::~Initializer() + 22
13 com.adobe.premiere.frontend 0x000000010c778fb3 FE::(anonymous namespace)::FullInitializer::~FullInitializer() + 49
14 com.adobe.premiere.frontend 0x000000010c779d25 FE::Initializer::PrivateImpl::~PrivateImpl() + 29
15 com.adobe.premiere.frontend 0x000000010c778f4a FE::Initializer::~Initializer() + 22
16 com.adobe.premiere.frontend 0x000000010c783d45 AppMain + 453
17 com.adobe.premiere.startup 0x000000010c8f41d7 Run + 247
18 com.adobe.AdobePremierePro 0x00000001000038b7 main + 647
19 com.adobe.AdobePremierePro 0x000000010000361c start + 52Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff927c3d16 kevent + 10
1 libdispatch.dylib 0x00007fff915f4dea _dispatch_mgr_invoke + 883
2 libdispatch.dylib 0x00007fff915f49ee _dispatch_mgr_thread + 54Thread 2:
0 libsystem_kernel.dylib 0x00007fff927c30fa __psynch_cvwait + 10
1 libsystem_c.dylib 0x00007fff8bdf4fe9 _pthread_cond_wait + 869
2 com.apple.CoreServices.CarbonCore 0x00007fff8e067210 TSWaitOnCondition + 108
3 com.apple.CoreServices.CarbonCore 0x00007fff8e0673e7 TSWaitOnConditionTimedRelative + 132
4 com.apple.CoreServices.CarbonCore 0x00007fff8dfc9b14 MPWaitOnQueue + 252
5 com.adobe.ASLFoundation.framework 0x00000001005c0770 ASL::(anonymous namespace)::TaskProc(void*) + 160
6 com.apple.CoreServices.CarbonCore 0x00007fff8e03e7e0 PrivateMPEntryPoint + 58
7 libsystem_c.dylib 0x00007fff8bdf07a2 _pthread_start + 327
8 libsystem_c.dylib 0x00007fff8bddd1e1 thread_start + 13Mac Pro 2 x 2.4Ghz, 16GB RAM, GTX 660
Grégoire Giral
May 30, 2013 at 5:50 pmHi everybody !!
I had the exact same problem (PPro CS6 was crashing anytime i tried to quit). I don’t know if my solution will work for everybody but it worked for me !!
The crashes started three weeks ago when i accidently open “Disk Drill” (HD manager,cleaner). At first i didn’t make the conection because i tought i’d close “Disk Drill” right away. The thing is, “Disk Drill” wasn’t close, it was on background operating…
Once i’ve notice that, I closed it (for good this time), and VOILA PPro stoped crashing.
So my solution is : close every HD manager, cleaner or any other software related to HD (that must be some kind of conflict in the autorisations).
Hope it will work for all of you or at least driving you to your own solution !
NaZa Giral
