Activity › Forums › Adobe Premiere Pro › CS6 (6.0.2) crashes on quit every time, any ideas?
Posted by Göran Thorén on January 10, 2013 at 11:04 amHi all!
A strange phenomena since about a week ago.
I have tried several projects, no Dynamic linked material so that could not be an issue.
Crashing on quit/close is of course not as bad as crashing when working on a project but still very enoying. Usually crashes like this has other underlaying issues which could be serious and I want to find out what it is.These are my specs:
OS10.6.8
2 x 2.66 GHz 6-core Intel Xeon
12 GB 1333 MHz DDR3
NVIDIA Quadro 4000Grégoire Giral replied 13 years, 3 months ago 8 Members · 14 Replies -
Kevin Monahan
January 10, 2013 at 9:02 pmHave you updated to the latest version of Premiere Pro?
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Kevin Monahan
January 11, 2013 at 10:21 pmFor Mac users, yes. Crash on Quit could be a number of things. You might try making sure you have the latest drivers, repair disk permissions and delete your preferences. If these things don’t work, an uninstall/reinstall might be in order.
Kevin Monahan
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Göran Thorén
January 15, 2013 at 1:53 pmThank’s for the suggestions!
I actually reinstalled Premiere and the crash occured again. I did the usual update process to the latest version and the application manager started it’s thing. During the update process I quit Premiere and this time it didn’t crash!!!???
But after the update was completed the problem is back…This is driving me nuts!
Cade Muhlig
January 18, 2013 at 6:59 pmI’m having the same issue. I have a feeling it has to do with the kona lhi or that I’m running on a hackintosh
Göran Thorén
January 18, 2013 at 11:09 pmHmm… I don’t have a Kona card in mine and no hackingtosh either.
But I do have an Nvidia 4000. -
Tom Daigon
January 19, 2013 at 5:12 pmI have a Kona card in my HP Z820 and its solid as a rock. Also had one in my 2008 Mac pro.
Make sure you have the most recent AJA driver and AJA/Adobe driver.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=DxPrG3WUyz8
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
Darius Wilhere
January 22, 2013 at 5:45 pmI’m having the exact same problem except after I re-installed Premiere Pro instead of crashing every time it hangs and literally even a day later won’t close unless I force quit it.
I’ve never had this problem before, so it’s really frustrating.
I’m using Mac Pro 2010, OS 10.7.5 with 32 gigs of Ram, Nvidia 4000 Mac.
If you figure out what’s happening please share!
Best,
Dare
Göran Thorén
January 22, 2013 at 6:38 pmSorry to hear that you have the same problem.
I have discovered another thing that doesn’t work;
When I change the metadata on RED files in Red Cine X, the files doesn’t update in Premiere. I bet that is related somehow.
I’m thinking of removing the Quadra card to see if that could be the issue. I have experienced some other issues since I installed it. -
Michael Cox
February 16, 2013 at 12:34 amSame issue here, pretty well every time I save and close Premiere Pro 6.x (always have the latest update) it hangs, lots of drive activity in the background too. I have to force quit it to get it to go away. I’m using a mac pro 2.8GHz quad core, so its by no means the fastest, 16GB ram, OS 10.8.2. It is annoying. I”m writing Adobe about it, suggest everyone else experiencing this do likewise:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
You have to log in to comment.
