Activity Forums Adobe Premiere Pro cs6 2nd monitor fileds problem
  • cs6 2nd monitor fileds problem
    Posted by Ryan Duff on June 4, 2012 at 4:38 pm
    I am running Premiere CS6, on a MacPro . as my primary monitor i have a Apple 30″, as my second monitor I’m using a DVI to HDMI adapter and running a 42″ plasma as my playback monitor.
    I found the playback settings to get the video to the 2nd monitor. BUT its only displaying one field of my SD interlaced footage. in the primary window i have it set to display bold fileds and full resolution, but i cant find those setting for the video getting output to the 2nd monitor.
    any suggestions?
    Kris Merkel replied 14 years, 3 months ago 4 Members · 4 Replies
  • Bret Williams
    June 4, 2012 at 5:54 pm
    If you want to display fields, and proper color, you’ll need to get something from BlackMagic, Matrox, AJA, etc. for monitoring. If you’re ok with SD, you could alternatively hook up a DV Camera or Deck and monitor through that.
  • Ryan Duff
    June 4, 2012 at 6:16 pm
    i relise what i’m seeing is scaled up and no where near broadcast quality. But my 2nd screen is clearly line doubling one filed and my text is unreadable. Where as my preview window in Premiere looks fine, even at 200%.
    I have done this same thing in CS5 with no problem, the 2nd screen ‘inherited’ its settings from the preview window in Premiere.
    i was hopping that the 2nd monitor just got its OWN preferences somewhere and i could not find them.
    this kinda feels like a bug.
    Ryan Duff
    ryan@ryanduff.com
    http://www.ryanduff.com
  • Tero Ahlfors
    June 4, 2012 at 6:58 pm
    Check out your display settings. The Nvidia control panel has settings for interlaced and progressive scan under the “change resolution”-tab. Dunno about ATI cards.
  • Kris Merkel
    June 5, 2012 at 1:54 pm
    Hi Ryan,
    I hear this question all the time, and the simple answer is that computer monitors will not show you interlaced footage correctly. Hence the need for an external broadcast monitor.
    A good example is the one you stated in the post while another would be your fields being reversed. Monitoring on a computer monitor is never going to show you any issues that might come up while working with an interlaced source.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Specialist, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS 5.5
    FCP7 and Studio
    Blackmagic Design UltraStudio 3D
    AJA IO XT
    FSI LM-2340W
