Activity Forums Adobe Premiere Pro CS5 Ultra Keying Eyedropper Not Working
  • CS5 Ultra Keying Eyedropper Not Working
    Posted by Michael Christopher on August 19, 2011 at 4:07 pm
    I have a MacBook Pro 13 8 gigs of ram (early 2011) running CS5 Production Suite. When I try and use the eyedropper to select the key color nothing happens. I can see the cursor turn into an Eyedropper but I can select a color. The color square next to the Eyedropper in the effects panel stays black. Anyone seen this and resolved the issue?
    Kevin Long replied 14 years, 4 months ago 5 Members · 10 Replies
  • 10 Replies
  • Ben G unguren
    August 19, 2011 at 5:20 pm
    I just experienced a problem this morning that might be related. I do most of my keying in AE, but I needed some temp keys and used Ultra. When using the eyedropper I did get colors, but the color over which my eyedropper was hovering was NOT the color that appeared in the color window. It was as though the eye dropper was picking up colors nearby, but I couldn’t figure out the pattern.
    My best guess was that this was related to the fact that (1) some of the images I was keying had already been scaled in the project window, and/or (2) the Program window wasn’t at 100% size, but using “Fit”. But even showing my footage at full-size and the window at 100% doesn’t seem to fix the issue (I’m using 4K red footage, btw, PPro CS5, OS X). Since these are temp keys anyway it hasn’t been too much of a concern — I’ve been eyeballing it with reasonable success. But +1 to your inquiry. Feels like a bug to me, but I’d like to hear of anyone else’s experience before reporting it….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Todd Kopriva
    August 20, 2011 at 1:13 am
    What operating system? Lion?
    Have you installed the latest Premiere Pro updates?
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Michael Christopher
    August 20, 2011 at 1:17 am
    Yes. I have installed all of the latest updates.
    August 20, 2011 at 1:20 am
    Yes the operating system is Lion.
  • Todd Kopriva
    August 22, 2011 at 6:39 pm
    We’ve identified and isolated a bug that causes the eyedroppers to misbehave on Mac OSX when you’re using multiple monitors. The bug is specifically regarding the use of multiple monitors when they have different vertical resolutions. If you’re not using multiple monitors with different vertical resolutions, then we really want to know about that, because that would be a different bug.
    August 22, 2011 at 6:41 pm
    I got it to work with a single monitor. Why won’t Adobe just admit this feature doesn’t work in CS5? Clearly it works in CS5.5 and you guys are aware of that.
  • Todd Kopriva
    August 22, 2011 at 6:53 pm
    We’re still investigating what’s going on.
  • Ben G unguren
    August 24, 2011 at 1:02 pm
    Yup. I have two monitors with different vertical resolutions.
    Ben Unguren
  • Glenn Lock
    April 12, 2012 at 6:49 pm
    Has there been any resolution to this keying issue using Ultra Key? I have disabled my 2nd monitor and tried a host of other things without success. Please help! Your message says that Adobe was investigating it, but I don’t see any further feedback.
    Thanks.
  • Kevin Long
    May 2, 2012 at 2:58 am
    I run Lion on a single monitor MacBookPro and all I ever get is the dreaded black box when using the eyedropper. But I have sequence that has been mixed down from a two-cam multi-cam source sequence. Can’t eyedrop the original video nor the mixed sequence. Up-to-date with patches I believe.
    Running CS5.
