Activity › Forums › Adobe After Effects › CS5: Prores Output Lost
Posted by Mark Reese on August 16, 2010 at 6:34 pmI had CS4 installed on my MacPro (the same machine FCP is installed on) and when I installed CS5, I lost the ability to export prores files. Anyone have any advice? Thanks.
Mark Reese replied 16 years, 1 month ago 2 Members · 3 Replies -
Mark Reese
August 16, 2010 at 8:09 pmYeah, I’m using the Render Queue. Prores is not available there (only lossless) nor is it available to set as a default under Edit > Template Settings > Output Module.
Walter Soyka
August 16, 2010 at 8:17 pm[Mark Reese] “Prores is not available there (only lossless) nor is it available to set as a default under Edit > Template Settings > Output Module.”
ProRes is not a default output module — but you should be able to select it by editing an output module and choosing ProRes as the codec under Video Output > Format Options.
See Output modules and output module settings for more.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Mark Reese
August 16, 2010 at 8:23 pmI’m an idiot. Thanks. Reading comprehension is apparently a system requirement for CS5.
