Activity Forums Adobe Premiere Pro CS5 Preview Stutters with Quardo Card
  • CS5 Preview Stutters with Quardo Card
    Posted by Chuck Pullen on July 29, 2010 at 2:31 pm
    I just recently installed a Quadro 3800 card in my pc. I am using the DVI and one of the Display ports with adapter for my pair of monitors. I am running CS5 and Windows 7 64-bit. It was running fine with a pair of basic video cards with no problems, but now that I have installed the Quadro card the preview stutters or jumps frames (backwards I think) every second or so. I have read all of the threads on stuttering video, I have made sure the latest drivers are installed, I checked setting for Mercury and hardware, everything seems correct. I did notice it only does this on certain files types but not others. I also use Vegas and tried a couple of graphic intensive games with the new card and everything else is working great.
    Anyone have any ideas?
    Chuck Pullen
    Jeff Pulera replied 16 years, 1 month ago 2 Members · 1 Reply
  • Jeff Pulera
    July 29, 2010 at 11:55 pm
    Hi Chuck,
    This may go against reason, but check the preview settings in the monitor window – I think default is 1/2 resolution. It will play smoother at FULL, at least that is my experience with CS5 and AVCHD clips.
    Jeff Pulera
    Safe Harbor Computers
