Activity Forums Adobe After Effects CS5 How can I create an ellipse-shaped anim w/ transparency outside the ellipse?
  • CS5 How can I create an ellipse-shaped anim w/ transparency outside the ellipse?
    Posted by Charlton Rom on April 29, 2012 at 2:34 am
    I want to create a banner anim for a website, the animation needs to be ellipse-shaped, then the F4v (that’s my current plan) will sit high up on the webpage. The effect therefore is an elliptical shaped animation on the page background, like looking through an ellipse shaped window or porthole. But I don’t know how to get what’s outside the ellipse to be deleted or transparent, since the composition is rectangular (570×82). It’s easy in Photoshop, just invert the selection and delete, but how do I “delete” what’s outside the ellipse, so my composition has an elliptical nature and look?
    Houston TX
    Roland R. kahlenberg replied 14 years, 4 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    April 29, 2012 at 2:37 pm
    Lots of ways in AE – the easiest, if you had a single layer OR if you nested your multi-layered composition into another composition, is to use AE’s Mask Tool.
    Mouse down on the Mask Tool and select the Ellipse Tool. Then draw the required shape.
    The following isn’t meant as a put down but please post beginner questions in the COW’s AE Basics Forum.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
