Activity Forums Adobe Photoshop CS5 fails to import first frame of QT
  • CS5 fails to import first frame of QT
    Posted by Galen Fott on November 13, 2010 at 3:17 pm
    I’m having a problem I’ve encountered before CS5, which is that Photoshop is failing to import the first frame of a .mov file. I render a video from After Effects, Animation compression, Best quality. I check it in QuickTime, and all the frames are there. I open it in Photoshop, and the first frame I get is actually the second frame of the file. No way to access the first frame in Photoshop.
    Any insights?
    Galen Fott replied 15 years, 9 months ago 2 Members · 2 Replies
  • David Johnson
    November 14, 2010 at 3:46 am
    I’m not familiar with this issue, but as a workaround until you get a better answer, perhaps just add a frame of black at the head of your MOV … you could do obviously do that in AE, but since you’ve rendered already, you could also do it in QT Pro. Hope this helps.
  • Galen Fott
    November 14, 2010 at 3:52 am
    Right, I’ve been adding a frame in AE at the beginning as a workaround, but this creates other problems as well…it’s just annoying that it doesn’t work properly! Thanks though, and I’m hoping someone will know what’s up with this problem.
