Activity › Forums › Adobe Premiere Pro › CS5 export of HDV 18 minute project via Media result h.264 HDTV VERSION has no audio
  • CS5 export of HDV 18 minute project via Media result h.264 HDTV VERSION has no audio
    Posted by Susan Mann on January 4, 2014 at 8:14 pm
    Hi
    I’ve just discovered your site. It looks great. Thank you all for helping the rest of us out.
    Client wants an MP4 version (i also need to figure out how to send it FTP)
    Working with HDV, in CS5 – edited the video down to an 18 min
    HDV project – exported via Media encoder –
    it output only the video …as a M4P. 2.6GB
    I selected: H.264/hdtv 1080, 29.97 hi quality,
    Window showed it would output AUDIO/VIDEO – into the final file
    OUTPUT IS:
    NTSC
    Frame width 1920 X
    Frame height: 1080,
    29.97 FPS. (it’s de-interlaced, aac,
    160 kpbs, 48 khz, tereo, lvbr, 1 pass, target 32.00, max 40. mbps
    BASIC SETTINGS: MULTIPLEXING: mp4
    Stream Compatibility: standard
    didn’t touch the ‘use maxiumum render quality’ no “use previews”
    “use Frame blending”
    Should i Use the above 3 items…
    So no audio, just video…
    and my CS5 project lost all it’s rendering…how can i prevent that.
    should i have nested the project onto another Sequence, and then exported it to media?
    Susan Mann replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
