CS5 Export Issues
Working in the PAL environment, I want to be able to import AVCHD 1080 50p footage, edit it and export it at 1920 x 1080 for playing on a full HD TV via a USB stick. I have tried MPEG2, H264 and WMV files. All work OK (at least on my computer) until there is movement across the screen and then there is jerkiness and a strobing effect. I have noted that this is not a problem with blu-ray. Can anyobe suggest editing and export settings to overcome this issue.
