Activity Forums Adobe Premiere Pro CS5 Capturing Issue with SONY HVR-M15U FW800 and Pre Roll
  • CS5 Capturing Issue with SONY HVR-M15U FW800 and Pre Roll
    Posted by Jonathan Clauson on June 29, 2010 at 12:23 am
    Okay, so I am running with CS5 Premiere on a MacPro4,1 (2.26GHz 8 Core Intel) with the GTX 285 card. I am saving up my money for the AJA cards, but until then I am using my trusty SONY MVR-M15U HDV deck via FireWire 800. It has served me well in Final Cut for the last couple of years, but with Premiere it is like it can’t capture anything.
    The issue is that while the deck is getting into position for pre-roll, it is like it can’t figure out how to do slow frame advancement and it will constantly try to fast forward into position and by the time the tape stops, it has rolled past the 10, 15 or even 20 second pre-roll position. Then when it tries to back up, it shoots back even further and it goes back and forth like a tennis ball before it gives up.
    With Final Cut I have tested it and it works just fine on a 10, 15 and 20 second pre-roll setting so I am capturing with Final Cut and editing in Premiere, but it would be nice to capture in Premiere as well. 🙂
    This is the same on DV or HDV footage so far only on miniDV tapes as I don’t have any DVCAM tapes to test with.
    Any ideas?
    – J
    Jonathan Clauson replied 16 years, 2 months ago 1 Member · 1 Reply
  • Jonathan Clauson
    June 29, 2010 at 1:51 pm
    Okay, I found the answer over on another forum and will post it here for those like me who are crawling out of the Final Cut Pro ooze.
    Premiere CS5 can’t capture via FW 800. The timing signals it sends to my deck are for FW 400 so it gets messed up. Go figure.
    So, since the MacPro 4,1 doesn’t have any FW 400 ports, I am forced to use Final Cut to import and then dropping that footage into Premiere. That being said, now I have to figure out what the best codec to use is between the two since FCP likes Pro Res and Premiere likes H.264 I think….
    – J
    Wishing everything would just work
