Activity › Forums › Adobe After Effects › CS5 Audio sync problems
Posted by Michael Rosen on May 11, 2010 at 9:19 amI am getting a ram preview issue in AE cs5.
The aif audio file is being shifted at random when scrubing (though the wave view looks correct). the ram preview won’t correct itself unless I purge then preview from the start of the comp.Renders seem to get screwed too.
Seems like a major bug….
Anyone else??????Luis Ozonas replied 15 years, 5 months ago 8 Members · 18 Replies -
Todd Kopriva
May 11, 2010 at 2:38 pmIf anyone else is seeing this issue, please report back by saying what kind of audio file you’re using. Then, convert the audio to another format (such as WAV) and let us know if that works better. If you want to attach a file to a bug report, send it to aebugs [at] adobe [dot] com.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Michael Rosen
May 11, 2010 at 7:22 pmOKay, I’ve reported it……It now seems that, if I convert it to wav I get much better (so far all-good) results
Uli Plank
May 12, 2010 at 6:42 amAny serious program for video production hates compressed audio. And me too!
Audio compression is the very last thing to do in a production chain, the space needed for uncompressed audio is ridiculous compared to HD video.Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
Michael Rosen
May 12, 2010 at 8:41 amIt absolutely WAS an uncompressed .aif file.
The work around is to convert it to a .Wav for now.Before I figured that out, I was using logic to redo the audio.
Uli Plank
May 12, 2010 at 9:10 amStrange. Sure about the sample rate?
Michael Rosen
May 12, 2010 at 9:29 amAif, 44.1, and 16bits.
I was working with 1 layer which was a retimed proress 422 HQ 1080 file at 29.97fps
and 1 adjustment layer for a vingett. Thats it.
Happened repeatedly audio would skip, repeat…be in the wrong place etc.
I heard of others with this problem in Cs5.
Adobe knows now. -
Uli Plank
May 12, 2010 at 3:40 pmThe audio should be 48 kHz for video. 44.1 is typical for CD.
Michael Rosen
May 12, 2010 at 6:12 pmThe way After Effects works, I don’t think it makes a difference at all.
It never has before.
But, as soon as my clients let up, I’ll do a test.
Thnks. -
Martin Edlund
May 16, 2010 at 10:06 amI have the exact same problem. With previews it’s okay if it doesn’t work perfectly (even if it’s annoying as h*ll), but the real problem is that even the renders get messed up. I also use 44khz 16 bit aiff, it has always worked for me before CS5.
