Activity › Forums › Adobe After Effects › CS5 Audio sync problems
Guillaume Charron
May 26, 2010 at 2:34 pmWe do have the same problem. We worked with wave and aiff audio. Both gave us problem with the ram preview and the render. Before, with cs4, we did have that problem.
Martin Edlund
May 26, 2010 at 2:39 pmIt actually seems to work better when I convert the audio files to wav. I would prefer to be spared from this step, but at least it’s better than no audio at all (or wicked audio).
Rob Mcdougall
May 31, 2010 at 11:14 pmJust to chuck my hat in – I’m also getting this problem with an AIFF I generated from Ableton Live. Weirdness.
Todd Kopriva
June 23, 2010 at 3:28 amHere’s a new technical support document on this issue, which acknowledges a known issue with AIFF, recommends transcoding to WAV, and mentions a fix that is in the works:
“Audio playback or RAM preview is scrambled or jumps around in After Effects CS5 or Premiere Pro CS5”
https://kb2.adobe.com/cps/851/cpsid_85192.html———————————————————————————————————
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Todd Kopriva
September 2, 2010 at 5:19 amThe Premiere Pro CS5 (5.0.2) update fixes issues with AIFF audio as well as many other problems. Please install the update and let us know whether your problem is fixed.
See this page for details about the Premiere Pro CS5 (5.0.2) update:
https://bit.ly/djiyh4Please report bugs that persist after the update here:
https://www.adobe.com/go/wish———————————————————————————————————
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Luis Ozonas
April 10, 2011 at 4:18 pmI’ve solved the same sync problem in AE replacing the .aif with .wav or a simple .mov quicktime movie containing the sound. Any sound editor capable to save as one of these formats will do the job.
Todd Kopriva
April 10, 2011 at 4:40 pmLuis,
You shouldn’t need to do this, since the updates that I mention above fix issues with AIFF files.
Luis Ozonas
April 10, 2011 at 5:00 pmHi Todd,
Yes you’re right,
just to add this solution which works fine with another AE versions. This is an old issue in AE.
