Activity Forums Adobe Premiere Pro Cs5 and graphics cards
  • Cs5 and graphics cards
    Posted by Suraj Dass on January 22, 2011 at 11:55 pm
    Hi Guys,
    Looking for some guidance.Was running Cs3 on my old dual core for a long time until I decided to upgrade to Cs5. Now Cannot seem get it right. Frequently crashes ( blue screen), unable to export HDV footage-keeps crashing.I hope someone can offer advice as this is really getting me down.
    System : gigabyte X58A-ud3r / I7 930 2.8 gHz / 6 Gb ram / GTX-460 on windows 7
    Editing footage from Sony Z5 and Z7 HDV
    Many thanks
    Suraj Dass replied 15 years, 6 months ago 4 Members · 14 Replies
  • 14 Replies
  • Deleted User
    January 23, 2011 at 12:36 am
    What crash are you getting exactly? Other questions
    1. What footage are you importing into Premiere
    2. What are your project settings
    3. When do oyu Blue screen? What error do you get?
    4. What is isnatlled on the system? Any addtional software, do oyu use this for offce/internet?
    Leo
  • Brian Louis
    January 23, 2011 at 4:22 am
    [Suraj Dass] “GTX-460”
    When you are refering to “Graphics Cards” in your header are you using the hack to be able to run CS5?
  • Suraj Dass
    January 23, 2011 at 1:06 pm
    Hi Leo,thanks for the reply.
    I am importing DV/HDV footage -DV seems to work fine but with HDV I am unable to export to any format .
    Project settings for HDV are 1080i 25fps.
    Blue screen with display driver error when editing and when trying to export.
    other software installed is MS office CS5 photoshop/encore/AE.
    Nero 8
    Windows 7 ultimate
    No internet at all
    GTX 460 with latest drivers
    GX 750W coolmaster PSU
    6 Gb ram
    500GB system Drive Seagate 7200 rpm
    1.5 Tb video drive Samsung
    Pioneer Blu-ray
  • Suraj Dass
    January 23, 2011 at 1:09 pm
    Hi Brian,
    Thanks for the reply.
    I don’t know about hack for CS5? What is that?
    Do I need it? Where can I get it?
    I thought the drivers were sufficient.
  • Deleted User
    January 23, 2011 at 3:40 pm
    Hello,
    It could be Office causinga problem, also have you tried to go back a version for the gtx driver? I had a bluescreen crash when I was working with cs5. I have the hpxw8600 and I used the driver from HP for the grpahcis card no problem, as soon as I used the latest form the Nvidia website i got bluescreen crashes. Went back to the HP and it was working fine no problems.
    So look a tninstaling Office, then testing, then go back to a prevous GTX driver if you continue crashing.
    Leo
  • Jeff Pulera
    January 23, 2011 at 4:24 pm
    The Mercury Playback Engine in CS5 uses certain NVIDIA display cards to accelerate Premiere. The GTX 470 is approved, I don’t believe the 460 is, but if you search the web for “studio 1 nvidia hack” you will find instructions to easily tell Premiere that your card is approved and this will benefit performance.
    This may have nothing to do with your issue at all, but is something you would want to do to speed up editing in any case.
    Jeff Pulera
    Safe Harbor Computers
  • Brian Louis
    January 23, 2011 at 8:20 pm
    [Suraj Dass] “DV seems to work fine but with HDV I am unable to export to any format .”
    What formats are you trying to export HDV to?? Is this the only time it crashes? or are the crashes random?
    Like Jeff mentioned about the hack at studio1 here is the link:
    https://www.studio1productions.com/Articles/PremiereCS5.htm
  • Suraj Dass
    January 23, 2011 at 9:37 pm
    Hi Brian,
    Been trying to export HDV to mpeg2 and mpegDVD. Kept failing.
    Just managed to export to avi and then make dvd in encore successfully.
    perhaps I need to upgrade my card from gtx460 to gtx470.
  • Deleted User
    January 23, 2011 at 11:17 pm
    You do not need to upgrade your card, I am running cs5 perfect on an HP XW8600, Quad Xeon cpu, Nvidia Quadro fx3700.
    You could try a new clean build of your system
    1. Windows OS
    2. Graphics drivers
    3. System drivers via Windows update
    4. Quicktime
    5. Adobe Software
    6. Adobe updates
    7. Test using a different hard drive to store your Media, I preusme you are editing from a different drive not drive c?
    Then test and see what happens.
  • Brian Louis
    January 24, 2011 at 4:29 am
    A 460 is a good card if you use the hack, a 470 wouldn’t really gain you anymore at this time. I’ve been using a Gigabyte mobo and 460 vidio card with no problems with HDV, HDV is fairly low bitrate and easy to decode native, are you using tape from the Z5/7??
