Activity Forums Adobe Premiere Pro Cs5 and graphics cards
  • Suraj Dass
    January 24, 2011 at 11:42 am
    Hi Brian,
    managed to hack premiere 5.0 exported to mpeg dv and avi. both worked fine.used mercury engine but with preview checked.probably faster.
    Now I will try exporting to HDV. If that works then I will hold onto 460 card.Footage is from Z5/Z7 on DV tapes recorded in HDV.
    Thanks so much for your help. Your a star.
    perhaps do a clean install when I after I have exported important projects.
  • Brian Louis
    January 24, 2011 at 4:48 pm
    [Suraj Dass] “Footage is from Z5/Z7 on DV tapes recorded in HDV.”
    You might want to scrub the timeline and look for dropouts, footage ingested from tape from time to time can contain dropouts which can cause you grief.
  • Suraj Dass
    February 6, 2011 at 9:33 pm
    Hi Jeff,
    I managed to hack GTX 460 on CS5 version 5.0 but when updated to ver 5.0.3 – then apllied the hack-it does not work? followed intructions carefully as well.
  • Suraj Dass
    March 15, 2011 at 4:07 pm
    Hi ,
    After numerous problems withgtx 460, i upgrade to certified gtx 470. But this is worse. PP crashes / freezes. Windows service pack 1 also installed. anti virus disableed.latest drivers for 470.
    I hope someone has a solution. Giving up with cs5. will go back to cs4 or een cs3. Never had any issues with cs3.
Page 2 of 2
