Activity Forums Adobe Premiere Pro CS4 Render line stays RED on RED Footage and OUtput is windowed when rendered
  • CS4 Render line stays RED on RED Footage and OUtput is windowed when rendered
    Posted by Tj Williams on March 21, 2009 at 3:05 am
    My CS4 using RED Camera footage renders out a 1/8 window of the picture in output and I don’t know how to change it to render it’s output so the picture fills the 1080 or 720 screen area?
    using RED footage 1/8 playback, When I hit RETURN or otherwise render effects or work area the footage if it has been color corrected etc so there is an effect will not render. Is this just a problem with red footage or????
    TJ Williams
    Dp/Camera Operator
    Seattle WA USA
    Tim Kolb replied 17 years, 5 months ago 2 Members · 1 Reply
  • Tim Kolb
    March 21, 2009 at 5:05 pm
    Are you using the full res files? Are the project settings set for 1/8 files?
    What’s the full size of the files? Are they 4K?
    TimK,
    Director, Consultant
    Kolb Productions,
