Activity Forums Adobe Premiere Pro CS4 Premiere Pro – Graphic/AE Quality Issues
  • CS4 Premiere Pro – Graphic/AE Quality Issues
    Posted by Jamie Guse on June 12, 2009 at 7:57 pm
    Working on a video project that has both a Photoshop CS4 graphic and an After Effect CS4 animation inside of the project and when I see it on the pc and watch it on TV the Photoshop graphic and After Effects animation are very pixelized.
    Here are my settings for all of the programs:
    Photoshop:
    720 x 480
    Pixel Ratio – 0.91
    After Effects:
    720 x 480
    Pixel Aspect Ratio – 0.91
    Render highest quality
    Premiere Pro
    Standard Settings
    4:3 Interlaced
    29.97 Frame Rate
    .9091 – Pixel Ratio
    I render as a MPEG – 2 DVD Setting and make sure to use the NTSC Highest Qualilty Settings
    Use Encore to burn dvd and use the standard settings.
    Any ideas what is going on?
    Jon Barrie replied 16 years, 3 months ago 5 Members · 4 Replies
  • Tim Robinson
    June 12, 2009 at 9:00 pm
    When you say “highest quality settings” what do you mean, are you using presets? The default in Premiere for “high” uses variable bit rates, instead of constant. If it’s a small project with static images, you should try constant bit rates and go with the highest quality possible. To do that in CS4 in the premiere exporter, click the double arrow button near export video / audio (greyd out device central) for detailed tabs to appear (why it’s now hidden by default, I don’t know). Under the video tab turn quality up to 5 and down under bitrate settings click the drop-down by bitrate encoding and pick CBR. Anything around 5-6-7 Mbps should be good.
    Tim Robinson
    tim@erobinsons.com
    Pride-Mobility-Products
    Corporate Video Editor
  • Vince Becquiot
    June 13, 2009 at 4:04 am
    Are you sure the graphics are being interpreted as 0.9 in Premiere?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Rob Mack
    May 26, 2010 at 10:00 pm
    This post is pretty far in the past but we just ran across something similar and I was searching around for others with similar problems.
    We have a mix of CS2 and CS4 suites. Photoshop CS4 defines a D1 PAR as 0.91. Photoshop CS2 defines a D1 PAR as 0.9.
    PPro CS2 assumes a PAR of 0.9. PPro CS4 assumes a PAR of 0.91. I don’t think any of these uses 0.9091 (Vegas does, though).
    PPro takes these numbers very literally. If you create an image in Photoshop CS4 that is D1/0.91, PPro CS2 will treat it as “not quite right” and you can have poor image quality when you are fitting an image to your frame size.
    The image itself is still 720×486 but you have to make the PARs match in all three applications.
    Rob Mack
  • Jon Barrie
    May 26, 2010 at 10:20 pm
    The frame size is critical.
    NTSC can be 720×480 or 720×486.
    These 6 lines can make a huge difference, make sure there is a line for line or pixel perfect dimension match across the entire workflow.
    With CS4 and above the new PAR will never go back to previous PAR of CS3 products and below.
    The way around this is to work at the ascpect ratio that suits the visual composition (widescreen) and then export or switch Photoshop to a square pixel PAR. Then let the program import assets as square PAR and manually correct the PAR in the NLE.
    Quality should be maintained because the pixel dimensions are never different just the stretch at the end of the line, which can never be avoided that is just how SD formats work.
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
