Activity Forums Adobe Premiere Pro CS4 not importing well
  • CS4 not importing well
    Posted by Sid Bengeloun on April 11, 2010 at 4:36 pm
    Hey Guys. Just got adobe Premiere CS4. I’ve been trying to import some footage into it for editing but it’s either a hit or miss. I thought it was my computer and or graphics card but when i tried it on my PC instead of my laptop i had the same issue. I start with a new document HDV. With 720P at 25fps. And i tried importing footag but all i get it the first frame or so.. I Rendered an animation out of carrara withe 1280 X 768.. or whatever it was and it didnt budge.. Even after i pressed enter to render work area.. I tried importing some other footage and it didn’t work.. I then tried importing other 720P stuff.. some work some didn’t. But without audio. I imported a clip of Sherlock holmes in 720P. It looked nice.. but again.. no audio.. Do i need codecs? or something. I mean all the videos that i try to import play well in VLC.. I even tried changing the extension from avi, to mov, to mp4… Nothing.. CS4 even rejected MOV, and WMV… wierd.. ok.. well any ideas folks.. I ned this up and running asap. Becuse before i start working in after effects and all that i’d like to know this is working first.. or so god help me i’ll use Vegas.. =(
    Sid Bengeloun replied 16 years, 4 months ago 2 Members · 4 Replies
  • Jon Barrie
    April 12, 2010 at 9:42 am
    what codec are the files using? They might not be Premiere Pro compatible. Just because you can play it on VLC doesn’t mean another program can use it.
    – Jon Barrie 🙂
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
  • Sid Bengeloun
    April 12, 2010 at 1:53 pm
    I start a new Proj…
    Display Format TIMECODE
    Display Format AUDIO SAMPLES
    Capture Format HDV
    The sequence Presets I chose both
    DVCPROHD – 720P 24P
    HDV 1080P24
    Either 24..25….
    And the footage i have well..
    https://www.mediafire.com/?kyinm1wanmt
    I checked using GSpot. It didnt say I needed anything
    https://yfrog.com/1agspotwj
    I started a project in HDV.. 720P. And i tried importing some Video and its not working. Its stuck on the first frame only. Even When I Export. I exported an animation i did in Carrara in 720. Imported it into CS4 and it it stuck on the first frame. It’s not the only video that doesn’t work. A lot of my footage is not importing right. It’s running perfectly in VLC and even in Vegas 9. I don’t know why it’s not working. Any Help fellas. I thought it might be a Codec problem but it’s not . It should come withe Premiere. And i tried GSPOT and it said no codec needed. I’m primarily working with AVIs. I even tried changing the Extension. No luck Please. I need Help ASAP. Marketing assignment due soon.
  • Sid Bengeloun
    April 12, 2010 at 3:24 pm
    OK.. i just tried WINDOWS MOVIE MAKER ON WINDOWS VISTA AND IT WORKED BETTER SURE THE PREVIEW WAS LAGGED BUT IT EXPORTED FINE… WTFFFF
  • Sid Bengeloun
    April 12, 2010 at 3:28 pm
    OK…. THE RENDER OUT OF WINDOWS MOVIE MAKE IS WORKING…. I AM SERIOSULY CONFUSED>.. SOMEONE PLEASE HELP ME OUT…
