Activity Forums Adobe Premiere Pro CS4 – No Audio in exported movie
  • CS4 – No Audio in exported movie
    Posted by Joe Landau on November 14, 2008 at 1:50 am
    I am an amateur video maker. I just installed CS4 and imported SONY ACCHD clips. I tried to export Media (to my Hard Drive) using the following settings:
    Format: MPEG2-DVD
    Preset: NTSC Widescreen High Quality
    Export – Video (checked), Export – Audio (checked)
    Audio Format – Dolby Digital (I tried all formats, actually)
    Bitrate – 192
    When I played back the movie there was no audio..
    Prateek Jitendra replied 17 years, 10 months ago 4 Members · 3 Replies
  • Josh Townsend
    November 15, 2008 at 2:00 pm
    There a a/v sych bug recently confirmed at the Adobe forums. Basically HDV and ACCHD don’t work as advertised and are being fixed in ‘a future update’. If you ask me CS4 premiere is one big beta.
  • Joe Landau
    November 16, 2008 at 3:36 am
    I agree full heartedly about the Beta. What a BIG disappointment and a waste of time and money.
    Joe
  • Prateek Jitendra
    November 20, 2008 at 10:50 am
    Hi JOE,
    If you have used the presets and settings which you have mentioned above, you would get separate audio and video files i.e.; .m2v file for video and .ac3 file for audio. For MPEG2DVD, the multiplexing is off by default for all the presets. if you play back the video only file, audio won’t be there becuase audio is in another file. If you want audio and video in a single file, you will have to turn the multiplexing on under “Multiplexer” Tab or you can use MPEG2 format instead of MPEG2DVD.
    thanks,
    Prateek
