Activity Forums Adobe Premiere Pro CS4 Media Encoder-MPEG 2 Quality?
  • CS4 Media Encoder-MPEG 2 Quality?
    Posted by Ninetto Makavejev on July 2, 2009 at 9:02 am
    Well, I’ve run into my first disappointment with CS4.
    Actually I might be one of the few who was quite pleased with most innovations of CS4, and had almost no bad surprises.
    Now however, I have run into one: the quality of MPEG-2 encodes from SD PAL material. Granted, the material is rather noisy, and on the “up-side” I have found the media encoder in CS4 to be one of the fastest ones around… BUT:
    it seems the black-values and contrast are quite bad when encoding at CBR, 7,5 Mbps. I have encoded the same material with Canopus ProCoder at the same settings and the results are MUCH better… i.e. Contast/Black values are spot-on and the noise/block-iness are absent.
    I have also tried using a bit of Gausian Blur in the Adobe encoder but it doesn’t improve anything.
    I wonder if part of the problem is the fact that the original material is an Apple Quicktime PAL-DV file, and Adobe-PC has some wrong way of interpreting this format?
    Any comments/tips would be much appreciated.
    regards,
    Ninetto
    Vince Becquiot replied 17 years, 2 months ago 2 Members · 1 Reply
  • Vince Becquiot
    July 2, 2009 at 3:29 pm
    Did you you use the “use maximum quality” option in the little contextual menu on center right of the export window ?
    I never understood why it’s hidden there, but do forget about fast renders with this enabled, hope that helps…
    On a side note, Procoder alone costs about as much as the entire Adobe suite (at least it did when we got the 2.0 version, so you would expect a bit of improvement 🙂
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
