Activity › Forums › Adobe Premiere Pro › CS4 Interpretation Problems with MPG4 Files in Premiere and Media Encoder
  • CS4 Interpretation Problems with MPG4 Files in Premiere and Media Encoder
    Posted by Jeff Compton on August 22, 2013 at 12:49 pm
    I’ll warn you. I’m a bit of a technical novice when it comes to this sort of thing. And I sincerely appreciate anyone taking the time and patience with me.
    I’m currently doing a project where I shoot a short film (sketch) every day. The issue having may be that I’m still using CS4 to edit 1080p files (from my Samsung Gallaxy SII Skyrocket, because it’s always on me), but the breakdown of the issue is:
    – Occasional misinterpretation of orientation (sometimes showing vertically)
    – Odd frame rate interpretation (showing 23.97, and sometimes .0125 with the audio playing at the correct speed)
    – Occasional choppiness of video playback, especially when the frame is reoriented vertically (this is usually before the work area is rendered, so that may just be my problem)
    – This interpretations being inconsitent – sometimes all being 29.97 and horizontal and then altering the next time I reopen the project, or vice versa.
    – Media Encoder not being in sync with the interpretation of Premiere (both in orientation and frame rate).
    These projects are being made on the AVCHD setting with 1080p squarepixals at 29.97 fps.
    The computer I’m using is:
    Chip: Intel i7930
    Motherboard: GIGABYTE GA-X58A-UD3R
    Video Card: NVIDIA Quadro K2000
    Ram: 18gigs, Wintec One 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 / ADATA Plus Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
    OS: Windows 7 Ultimate
    I edited a film a couple years ago (before the computer’s video card started to act up and it went dormant until about 4 months ago) from NonHD MiniDV tape 24p (12 hours of footage) without any problem, and then again a few months ago without any issue.
    I don’t know if this is a problem CS4 has with what would have been considered a newer format at the time of its release, or a codex issue. I just don’t know how to research this, so, again, any help is greatly appreciated.
    Jeff Compton
    Jeff Compton replied 13 years, 1 month ago 2 Members · 3 Replies
  • Ann Bens
    August 22, 2013 at 5:19 pm
    CS4 does not support movies shot from a phone.
    What is the extention and codec?
    If its h.264 in a mov wrapper CS4 cannot handle it properly.
    This was corrected in later version of PP.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Jeff Compton
    August 22, 2013 at 5:36 pm
    Thank you for responding, Ann. Yeah, it’s H.264. I had a funny feeling that was going to be the issue. What version address this?
  • Jeff Compton
    August 22, 2013 at 5:43 pm
    Sorry, Ann. That was lazy. I can search on Google. Thank you for your help.
