Activity › Forums › Adobe Premiere Pro › CS4 export problem
  • CS4 export problem
    Posted by Glenn Axford on October 7, 2011 at 5:03 pm
    So im working on a seminar that has power point slides. I’ve brought edited the seminar with premier and then brought that file into AE to add the slides. I have the slides appear side by side the video of the presenter and there is also an alpha channel behind the split screen so i can add an effect.
    After, i bring the project back into premiere as an AE file. and i composite the background effects the AE file (with the slides and the presenter) and the audio. The problem i have is that on the timeline i cant see the AE file appear in the viewer while the play head is NOT moving. When i press space i can see everything fine but when i pause it the AE file disappears. I figured it was some small problem with the internal rendering of premiere so i sent it to export. But even now all i have is the audio and the background FX. Not the AE file.
    I am fairly new to Premiere. I have been using FCP for the last 4 years. But i thought this would be easier to use since i’m going back and fourth between AE and Premiere.
    Glenn Axford
    Glenn Axford replied 14 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
