Activity Forums Adobe Premiere Pro CS4 export is a touch fuzzy and color slightly pushed
  • CS4 export is a touch fuzzy and color slightly pushed
    Posted by Louis Klibansky on April 16, 2010 at 2:22 pm
    I have this strange issue with Premiere Pro CS4.
    Work flow:
    1 Import .mov file from flash disk recording from camera shot on green screen. Original format is HDCAM EX 1080p 25fps 180Mbps
    2 Created proxies with MPEG streamclip 720p Apple Intermediate codec
    3 created a 1080p HDCAM EX sequence
    4 imported 3 hours of footage (proxies) into Premiere Pro and selected 40min
    5 replaced proxy footage with full hd
    6 exported to 100% Apple Animation file
    7 imported into After Effects
    8 Keyed
    9 exported with alpha channel 100% apple animation 1080p
    10 created proxy of 720p 100% apple animation with alpha channel
    11 imported into Premiere Pro sequence for offline edit
    # 1st issue
    I notice that when I view the footage in Premiere Pro and compare it to the raw proxy, it’s a touch pushed in the color/exposure or something. Why is that? Can I adjust that?
    #2nd issue
    When I want to export the timeline and I compare the footage in the source monitor and program monitor and the export preview, I notice that the export preview is a touch fuzzy when set to animation codec 100% and not scaled. Why? When all other footage is crystal clear..
    I hope some one can help. Thanks
    Louis Klibansky replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
