Activity › Forums › Adobe Premiere Pro › CS4 Dynamic link and external drive.
  • CS4 Dynamic link and external drive.
    Posted by Joel Morrison on November 1, 2012 at 8:11 pm
    When I am in PPro and attempt to “replace with after effects composition”, the clip doesn’t show up in AE, only a placeholder (colored bars and such). All the assets are on an external drive. I am using the Master Collection on a Mac.
    It works fine when everything is on the Mac hard drive.
    So much learning.
    Joel Morrison replied 13 years, 6 months ago 3 Members · 13 Replies
  • 13 Replies
  • Alex Udell
    November 1, 2012 at 10:30 pm
    What’s the file system of the external drive?
    Maybe a partition you share between windows and Mac machines?
    just a guess….
    Alex
  • Joel Morrison
    November 2, 2012 at 3:13 am
    Thanks for the response Alex. I have nothing but Mac. I guess that’s HFS file system. No windows in the mix.
    So much learning.
  • Alex Udell
    November 2, 2012 at 11:15 am
    hmmmmm…..
    scratching head….
    can you you import assets into ae from that drive manually?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Alex Udell
    November 2, 2012 at 2:13 pm
    Joel…
    curious….
    when you are in the AE Project….
    are the assets for the project also in the project panel? (they should be)
    if so….
    can you right click them and manually relink the footage.
    I’m not suggesting you should have to do this….I’m just wondering if you can and if it’s a work around for now…
    Alex Udell
  • Ann Bens
    November 2, 2012 at 5:03 pm
    It’s better to work from internal drives then external drives.
    As ts already experienced
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Joel Morrison
    November 2, 2012 at 10:54 pm
    I can import assets manually. FYI if it matters, the external is an iomega 4 TB raid 1.
    So much learning.
  • Joel Morrison
    November 2, 2012 at 10:55 pm
    I can right click the color bar place holder an replace the footage. Audio too.
    So much learning.
  • Joel Morrison
    November 2, 2012 at 11:01 pm
    Ann
    I too find it better to work off the internal drive, but it’s to full of everything. I just think it should work though?
    So much learning.
  • Alex Udell
    November 4, 2012 at 5:23 pm
    How is the Raid connected to you machine?
    as local storage (SATA, USB, Firewire, etc)
    or a NAS (Ethernet) ?
    How do you format it? Disk Utility or Web Based interface?
    thanks…
    Alex
  • Joel Morrison
    November 4, 2012 at 9:56 pm
    It’s connected with firewire 800 and it was formatted with disk utility. The drive has 2 plugins for the firewire and I tried both.
    With this in mind I just now put some assets and started a Premiere Pro project on a little iomega USB powered drive, again formatted with disk utility. Guess what? It works. I can “replace with after effects composition”, and the clips appear.
    So then…the problem with my main storage and back up?
    Joel
    So much learning.
