Activity Forums Adobe Premiere Pro CS4 does not finish to load project and freezes
  • CS4 does not finish to load project and freezes
    Posted by Wim Roegels on May 3, 2010 at 2:23 am
    I am using CS4 on a Mac and I am not able to reopen a project (autosaves same issue). The strange thing is, I can open an older Version and even without changing a bit and saving it as a new file, the new project file will not open.
    What I did so far:
    – deleted all prefs
    – eleted all cache / render files
    – tested with different user
    – import in to a new project
    – cross checked on a macbook pro, same
    I also installed XML-Wrench on a virtual PC and used that tool to search for wrong chars in file names, nothing found everything valid.
    I am really angry with the all in all performance of a “professional” tool acting that strange.
    There is a working project file and just with saving it, it gets broken … client is waiting, what to do?
    Brian Barkley replied 16 years, 4 months ago 2 Members · 1 Reply
  • Brian Barkley
    May 3, 2010 at 11:58 am
    I would think that creating a new project, then copying and pasting from the old project into the new would do the trick.
