Activity › Forums › Adobe Premiere Pro › CS4 Codec Support?
  • CS4 Codec Support?
    Posted by Naz Gassiep on November 18, 2009 at 7:25 am
    So I need to open DV and HDV files in Premiere. I have just install Adobe Premiere on a fresh install of Windows XP. Virtually every file I attempt to open in Premiere gives me a format not supported error.
    Where do I get the commonly used codecs (DV, HDV, MPEG2ts, H.264, H.263 etc) from and how do I get Adobe Premiere to recognize them?
    Tim Kolb replied 16 years, 10 months ago 2 Members · 3 Replies
  • Tim Kolb
    November 18, 2009 at 2:53 pm
    It sounds like you’re running the software in demo mode…as soon as you put in a serial number it will add the codecs.
    TimK,
    Director, Consultant
    Kolb Productions,
  • Naz Gassiep
    November 18, 2009 at 3:00 pm
    Actually that’s not the case, I have entered the serial number and the product appears to be properly activated. However, I did not register with Adobe. Surely that’s not required for the codecs?
  • Tim Kolb
    November 18, 2009 at 4:47 pm
    “Registering” as in providing a ton of info isn’t required, but the machine with the software has to be on the internet and ‘activate’ the serial number…then the codecs should download and install.
    TimK,
    Kolb Productions,
