Activity › Forums › Adobe Premiere Pro › CS4 capture image SMALL
  • CS4 capture image SMALL
    Posted by Bonnie Bucqueroux on January 9, 2010 at 12:58 am
    I just upgraded to CS4 and am trying to capture mini-DV as before – not HD – from a Canon GL2. The captured image is SMALL, though it says it was ccaptured at 720 by 480. I cannot seem to find anyplace to change settings – can you help? Will I also need to recapture to make the size larger?
    I am, of course, on deadline this weekend to produce two YouTubes that must look like one done on the machine that died (three computers ccommitted different kidns of suicide over the holidays).
    Sorry to sound frazzled, but I am.
    Brian Louis replied 16 years, 8 months ago 3 Members · 2 Replies
  • Mike Velte
    January 9, 2010 at 11:37 am
    If the resolution of the video is smaller than the Sequence window one of 2 things could be the cause;
    1. The Zoom level of the Window might be set to something other than “Fit”.
    2. Your Sequence preset was for much larger video.
  • Brian Louis
    January 9, 2010 at 11:39 am
    What are your project settings? where are you seeing the small image? is it in the program monitor? If you have a 720×480 project setting, and you are seeing the small image in the program monitor is the little box at the bottom have “fit” checked?
