Activity Forums Adobe Premiere Pro CS3 Video Transitions not playing
  • CS3 Video Transitions not playing
    Posted by Roly Poly on May 3, 2008 at 12:56 am
    Greetings,
    I began working on a project. I made the clip cuts, added the needed transitions. In between the clips, the purple transition (ex. Cross Dissolve, Wipe, etc) are present on the timeline, however, when I try to preview, they do not appear. I try rendering the project…and still nothing!!!
    I did delete, for example, a cross dissolve transition and reapplyed it to the clips… It then did work!! Is there anthing else I can do in order to avoid reapplying all transitions???
    Rolando
    Roly Poly replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
