CS3 suddenly running slowly; disappearing render bar to blame?
first time posting. Allow me to say that I am almost completely computer-illiterate, so if you are kind enough to reply to this thread, please, PLEASE speak slowly, and in terms that an 8-year-old might understand.
I have PP CS3, and a relatively new Vaio NW with 4 GB of RAM and 320 GB of memory.
Last night I was editing for several hours, and everything was going swimmingly until Premiere started acting REALLY lag-gy. I closed and re-started, but nothing changed. I opened the task manager and noticed that Premiere was using over 1 GB of memory, which, I believe, is well over what is usually does. This morning I tried everything again, and now it is using over 2 GB (!) of RAM. My rendered project won’t play back w/o significant lag, even when I shrink the monitor window WAY down.
The only clue I can offer to you is that I noticed last night, when sh-t started going down, that the red/green “render bar” has disappeared altogether from my timeline (the project I’m working on is very edit-heavy and I am the type to render every minute or two; so the entire project was “green” when whatever happened happened).
Any ideas? I just ran a registry cleaner, and am currently running Defraggler, but I suspect there is a more elegant solution.
Hugs
