CS3 Position Keyframes not working
This was posted by someone last year, but there was no follow up:
“It is not allowing me to add keyframes,(I need at least 2)on the adjustment(levels)layer. I have tried it with the opacity layer for the adjustment, if I’m changing the opacity it works just fine(move down the timeline change the opacity again, it then sets a new keyframe).”I’m having the same problem. Position timeline isn’t working. Keyframes work fine on Opacity and Style timelines, but not on the Position timeline. Set the first keyframe, move the time marker, reposition the element, and a keyframe should be placed, but that’s not happening. Manually placing a key doesn’t work either. It’s working fine in CS3 on my Laptop PC, but not on my Mac. PS CS3 Extended is running on a Mac G5 1.6ghz tower w/ Leopard 10.5.5, 1.5g ram, lots of scratch space…
Oh, and I’ve been using Photoshop forever…but I’m used to using ImageReady for animation. Sure would like to get this working on my Mac.
