Activity › Forums › Adobe Premiere Pro › CS3 OR CS4 will it load & operate on windows 7 64 bit ?
Posted by Scott George on January 19, 2010 at 11:01 amWill it function properly ?
John Moss replied 16 years, 5 months ago 5 Members · 4 Replies -
Brian Louis
January 19, 2010 at 1:45 pmI haven’t run CS3 on win7 64 but it ran ok on vista64 with some small strange OS problems, I run CS4 with win7 Pro 64 on a desktop and win7 home prem 64 on a laptop with no problems
Bala Chandran
January 23, 2010 at 4:22 pmCS3 will run great in Win7 64, but CS4 you cannot be sure until you install and run. CS4 depends highly on your machine and its components.
John Moss
April 13, 2010 at 7:04 pmHello Scott George,
It should work just fine assuming your PC is in a healthy condition!Just an FYI for you.
It is always best to check with the software manufacturer FIRST. They will tell you if they have tested the product and the version, as well as whether or not it will work with Windows 7.
Check out the Windows 7 Compatibility site: (There you will find out about hardware and software compatibility.)
https://www.microsoft.com/windows/compatibility/en-us/default.aspx
There is a pulldown from which you can choose “hardware” and “software”.There are also some great articles, instructional videos and such to help with your Windows 7 at our Springboard site:
https://technet.microsoft.com/en-us/windows/default.aspxIn any event a lot of the times, Vista drivers will work in lieu of Windows 7 drivers, however, it’s not 100%!
As stated previously, it’s best to have the Windows 7 certified drivers installed.
Thanks again,
John M.
Microsoft Windows Client Support
