Activity › Forums › Adobe After Effects › CS3 loses my footage
  • CS3 loses my footage
    Posted by Rob Wolf on September 19, 2007 at 7:08 am
    I’m experiencing an odd problem. I have an AEP with some footage imported from Premiere Pro. After saving, quitting After Effects, then reloading the program and project, AE can’t find the footage that I had just imported.
    For example, if the Premiere Pro file had 95 pieces of footage, I get an error that says “95 files are missing since you last saved this project.”
    Anyone seen this?
    R
    David Bogie replied 19 years ago 2 Members · 1 Reply
  • David Bogie
    September 19, 2007 at 2:48 pm
    Umm, PC or Macintosh?
    The only way I know of AE to lose the footage is if you have not used the built-in facility correctly. It’s a copout answer, true, but I know from extensive experience with a class of 15 aspiring AE newbies (running CS2) the file and project interchange system between Adobe video applications is almost flawless. Every issue we had was either user-based or had something to do with the network server geeks changing access privileges without telling anyone.
    bogiesan
